We are in the middle of a IPE decking job & home owner wants to include a snow melt system on deck that leads to a hot tub. The deck is above ground w/ 1×4 Ipe decking. I’m all for this but I have a concern of thermal shock on the wood, not looking for a warranty issue. Has anyone had any experience w/system on wooden decking?
Check with tech support of a system manufacturer
I can't imagine what you'd
I can't imagine what you'd use that would melt the snow on a deck. Best I can imagine is putting down some sort of heating mat on top of the deck.
I think alot would depend on how fast they want the snow melted. I could see installing an electrical resistance system at the bottom of the joists and not shocking the IPE.
But it might take a little longer to melt the snow.
If you installed it on the bottom of the joists you could put some framing on the outside to keep the warmth under the path. In case there was wind.
As it turns out, there is not a good solution. The manufacturer of the heat cable we used on the roof, said that the product requires conducting the heat generated through a substrate. Although Ipe' is more conductive than most woods, still not high enough to be effective.
We're going look for another way.
Have you come up with a solution yet? I am considering the same application and was thinking of just snaking heat cable underneath between the joists. Not sure if it would be effective, but it might do the trick. Here is a link to the product I'm considering
http://www.tycothermal.com/usa/english/heat_tracing/productsearch/all/productDetails.aspx?crd=3&cg=104&pcg=1132&nm=WinterGard+Wet
Well my solution is to cover the deck with heated living area, and do away with the deck! Honest!
I talked with a couple of engineers who work at the company who makes the cable you referenced. They said snaking the cable under the deck boards would not do it. The amount of heat generated by that cable is so small and it depends on being in close contact, as in concrete, to form a conductive path for heat generated. As we know air is a fine insulator.
Instead of going from below, what about using heat lamps instead? They can be placed in such a way during the winter season so they both light AND warm the path to and from the tub.
Snow would reflect most of the infrared light and not melt.
snow melt...
Years ago an architect name of James Lambeth designed a mirror melting system for the entry walkway for a ski lodge in Colorado. I don't know if it worked or if I even remember correctly but it was a novel idea.
'course I'm not suggesting it is practical for your application.
So could you say he wrote the book on the subject?
Some folks use heat cables up here although I haven't seen any on decks. They would probably work the same.
