soffit vents
| Posted in Construction Techniques on July 5, 2003 10:23am
I am building a new porch (new construction) and I also plan to improve the appearance of the existing exterior in several ways. I have become stumped as to how I can install the tongue and groove pine soffit boards, perpendicular to the wall, and still allow for sufficient vents. I’ve seen some houses that use the continuous soffit vent but their T&G runs parallel to the walls. The T&G is being installed over 1/4″ plywood if that matters at all.
Any suggestions? Am I stuck with those little round vent plugs? They seem horribly inadequate.
Thanks in advance.
Bill
Mukilteo, WA
  1. GCourter | Jul 05, 2003 06:24pm | #1
    COR-A-VENT has a fascia venting system. FHB advertiser http://www.cor-a-vent.com . I have used their product for more than 10 years.
  2. stossel1 | Jul 05, 2003 06:29pm | #2
    Why are you venting a porch roof?
  3. xMikeSmith | Jul 06, 2003 05:19am | #3
    bduff... we use a vinyl soffit by Alcoa it has a 3/8 profile and the j-mold has a 5/8 profile, the j-mold looks like colonial casing.. and the soffit looks like beaded ceiling..
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
  4. clampman2 | Jul 07, 2003 01:55am | #4
    You could cut your fascia shy of the roof sheeting by couple inches, apply spacing blocks, then add a shadow board (which will hang below the blocks by an inch or two) which your drip edge overhangs. Your soffit will then have no perforations. Obviously, this method depends upon continuous ridge vent.
    Like Sossel, I am curious why you are venting a porch roof.
    Clampman
  5. archyII | Jul 07, 2003 02:22am | #5
    "I can install the tongue and groove pine soffit boards, perpendicular to the wall"
    Why perpendicular?  I have only seen them installed parallel to the walls (bead board).  Vinyl (kinda look likes) bead board soffit typically gets installed perpendicular but it looks wrong.
  6. JimLovatt | Jul 08, 2003 12:02am | #6
    Here is an idea for you...
    http://quittintime.infopop.cc/attachments/6097-soffits.jpg
    Edited 7/7/2003 5:07:14 PM ET by Jim Lovatt
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
