Soffits under decks- dryspace
monti | Posted in General Discussion on December 22, 2006 07:42am
I have a client who has decided to soffit the underside of a deck with cedar. The deck has already been installed (trex decking on PT 2×8 joists- approx. 10’x15′) I have used the rain drain systems that are installed on top of the joists prior to decking, but have no experience using any of the systems installed after the deck is built. This is a higher end home, so I’m not too excited about using dryspace. Any suggestions?
  1. rez | Dec 27, 2006 11:40pm | #1
    Greetings monti,
    As a first time poster Welcome to Breaktime.
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    http://www.quittintime.com/
  2. rez | Jan 03, 2007 02:38am | #2
    Well monti, let's run this thru again.
  3. Dave45 | Jan 03, 2007 03:14am | #3
    Monti -
    When you say soffit, do you mean that they want to close in the structure under the deck?
    If so, it shouldn't be a problem as long as there are enough openings to allow the area under the deck to "breath".   Many houses around here have a crawlspace and when I do a deck on one, I make sure that the foundation vents don't get blocked so the crawlspace stays ventilated.
    For appearance - and total ventilation under a deck - I like to use architectural lattice.  The lattice is heavy enough to hold up and it hides the deck structure.
