I have a soft spot in a laminate floor I installed recently. I know what the problem is- there was a dip in the subfloor that I failed to spot and fill before I laid the floor. My question is, is there any way to fix it without having to take the whole floor back up. It’s a plywood subfloor over a crawlspace, so I can get to the underside. I’m wondering if I can drill some holes through the subfloor from the bottom and inject something under the flooring- floor leveler, canned non-expanding foam? to fill the void. Surely someone out there has run into this situation before. Any ideas? For the record I hate laminate flooring anyways but sometimes that’s what the customer wants (and what fits the budget). Any help is appreciated. Thanks!
we did this with an engineered thin 1/4 0r 3/8 in thick- can not remember - wood floor over concrete- drilled a hole maybe 3/8 inch maybe 3 or 4 holes injected something (10 years ago) and then plugged with those small plugs we stained to match- it was a good result- may have used construction adhesive- no foam.
worked well- sorry I do not have more details
If you can access from the underside, so much the better.
We have remedied the situation with non expanding foam through drilled holes (and don´t forget a little weight on top as all foams expand a little). Drill holes 3-4" apart and use less, rather than fill the void through one hole. Tape holes.
Greetings from Germany
Mathias
That was what I had in mind; drill a number of holes, maybe a piece of plywood with a weight on top to keep it flat and squirt in some non expanding foam. I think that's what I'll try if it worked for you. Thank you very much.
Why bother with the foam? If you have access to the underside jack/shim/support it back into place to remove the void.
What is it I'm missing?
Well I considered that and frankly I haven't even crawled under yet but I think it's probably a spot in the plywood subfloor that's low for some reason- I don't think it's a low joist because it's only a spot maybe 1 1/2 feet in diameter that's soft. I'd rather crawl under there with a drill and a can of foam then jacks and blocks and etc!
