softplan and vista
z1Man | Posted in General Discussion on August 30, 2008 01:06am
Hey guys I have a trivia question that I am trying to answer.  I assume that softplans newest version is vista compatiable,  they say “windows compatible”  but what is the oldest version of softplan that is vista compatible?  Or maybe I should try autocad.  Thanks for the help.
  1. Piffin | Aug 30, 2008 01:43am | #1
    Have you visited the Splash website?
    Softplan users forum
    Maybe you need a key# to loggin. I have not been there much since vista and I am still XP, but I can go check for you in a while.
  2. Piffin | Aug 30, 2008 01:51am | #2
    http://splash.softplansplsh.org/members/dcforum/dcboard.php?az=show_topics&forum=156
    This should get you into the guest forum
  3. TomE | Aug 30, 2008 02:13am | #3
    I'm using SP12 on my vista rig but Softplan "recommends"  SP14 for vista users.
    I've not done extensive drawing recently but the only issue I've had (so far) is the rendering engine.... I needed to turn off hardware acceleration to get my renders up and running.
    My guess is that one difference between XP and Vista for functionality in SP12 is support of hardware drivers.
    SP12 seems to work the same for me as it did in XP but there may be problems yet to be discovered.
    1. Piffin | Aug 30, 2008 02:34am | #4
      after browsing there a while it looks like there are some GUI and printer problems with V12 and Vista, but OK with V14
      1. z1Man | Aug 30, 2008 03:21am | #5
        thanks to the both of you I am trying to decide what program to use.  I did the search and there is a lot of disscussion on this subject.    Thanks again guys
        1. Piffin | Aug 30, 2008 03:36am | #6
          How do you plan to use it?What is your orientation/career?Are you a geek, a builder, or an architect?Is inter-compatibility important?What is your budget?Obviously I am a SP user and fan.Their are others that are great too
      2. TomE | Aug 30, 2008 06:39am | #7
        OK, that does seem to point to driver optimization or the lack thereof when running SP12 under Vista, thanks.
Grout-Free Shower Panels
  • A Postwar Comeback
  • Natural Simplicity
