Solar Panels, Spray Foam, Shingles
brad_c88 | Posted in General Discussion on December 19, 2021 08:57am
I live in CZ 4a. I will be building a house with an unvented attic, insulated with ccsf on the roof sheathing. I will also have asphalt shingles with tar paper as an underlayment. I also will be getting solar panels installed on my roof. My question is, will I have any issues with exterior drying on the shingles that are under the shingles since they will be covered from the sun?
    unclemike42 | Dec 19, 2021 10:52am | #1
    guessing you are worried about shingles under the solar panels. (not under the shingles)
    It is true that you will have slower drying of the covered shingles, but the solar panels will protect them from direct UV light, decrease solar heat gain on the shingles, and reduce impact from rain, hail, and stuff that falls from above (like tree stuff and other blown objects)
  2. catmandeux | Dec 19, 2021 03:43pm | #2
    Since solar panels will be up there for 25+ years, you should consider a roof that will last at least that long. Removing the solar panel installation to replace an asphalt shingle roof is an expensive extra to your roofing costs.
    A standing seam metal roof may be a better option, particularly if combined with a rack system that clips directly to the standing seams, avoiding any penetrations through the roof deck. It will be more initial expense, but probably less life time cost.
    tfarwell | Dec 23, 2021 01:32am | #3
    I've had solar panels on my asphalt shingles for 10 years. CZ 4 - Oregon / Maritime climate (wet). No problems, they dry out fine - you'll get a lot of air flow if they are mounted on the standard rack system. The shingles haven't shown any aging at all. I put moss-out above the panels twice a year, and the rain carries it down.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
