Soldering cop. pipe in a “closed system”
akjim | Posted in Construction Techniques on September 22, 2004 08:12am
Scenario: 1 inch copper LB leaked (hot water heat). Closed the nearest valves, cut LB with sawzall, drained, etc..
Problem: how to solder this LB. Valves on each side make it a “closed” system. No way for steam/pressure from torch to escape.
Advice?
  1. DanT | Sep 22, 2004 12:17pm | #1
    Cut the pipe a few inches away from where your ell is and install a union.  DanT
    NickNukeEm | Sep 22, 2004 03:42pm | #2
    Drill hole in copper pipe about 1/8th inch diameter somewhere in the vacinity where you're sweating.  Sweat as required.  Put flux on/in hole and on a BRASS screw that will screw into hole.  With screw screwed into hole, hit it with torch and solder.  Voila.  Have done this many times, still no leakers.
  3. davidmeiland | Sep 22, 2004 04:51pm | #3
    a pair of compression fittings would work, one on either side of the new ell
    the system should have provisions for draining the water, which would allow you to repair using typical sweat couplings
  4. DanH | Sep 22, 2004 06:32pm | #4
    You can also get a regular copper coupler with a weep valve (if you hunt around long enough). Install with valve open, then close valve. If you can't find the coupler, do the same thing with any sort of valve with a weep valve on it.
  5. csnow | Sep 22, 2004 07:03pm | #5
    If there is enough air volume in the piping, the pressure may not be significant.
    1. DanH | Sep 22, 2004 09:20pm | #6
      Or you can "preheat" the length of the pipe so that the air inside expands, then solder as it cools. You have to be careful, though, that the cooling air doesn't suck all the solder inside, leaving none in the joint.
