Soldering galvanized roof metal
theslateman | Posted in Photo Gallery on June 27, 2009 11:55am
A week or so ago in another thread on roofing  — Dino asked if galvy could be soldered properly .
Seemed like that was buried where not many folks might see the responces , so I thought I’d show some rivetted 26 gauge aprons being soldered to show the process .
Fluxed with muriatic acid , then sweated together .
Laced together in several passes so it doesn’t get too hot and run .
Once stitched fully the sides are fluxed and dressed .
  1. Piffin | Jun 28, 2009 12:13am | #1
    same flux as Copper?
    1. theslateman | Jun 28, 2009 12:17am | #2
      Nope , muriatic acid for galvanized or buy a special flux from a specialty outfit .
      I use a paste flux for copper .
      1. seeyou | Jun 28, 2009 12:55am | #3
        U'r a rivetting son of a gun. What type of rivets do you use on galvy? Steel rivets don't solder well and some SS rivets I've gotten don't take solder well either. We don't fool with galvy much anymore, but I used to breath a lot of muriatic fumes. I always had trouble with rust where the flux had been.http://www.quittintime.com/      View Image
        1. theslateman | Jun 28, 2009 01:29am | #4
          Steel , they are a little touchy , but you can see the results .
          I don't use it much anymore , but these folks wanted a bit less cost per sheet .
          Labor is basically the same . Be done there tomorrow .
          1. seeyou | Jun 28, 2009 01:53am | #5
            Nice stitching.http://www.quittintime.com/      View Image
          2. theslateman | Jun 28, 2009 01:56am | #6
            Why thank you matey !!
          3. seeyou | Jun 28, 2009 01:59am | #7
            Hey -
            I had an idea earlier. The two of us need to team up on a project, photo it very well, write a story and sell it to JLC. http://www.quittintime.com/      View Image
          4. theslateman | Jun 28, 2009 02:01am | #8
            Sounds like a plan Sam !!
            FatRoman | Jul 01, 2009 11:21pm | #11
            I think that's a great idea.But aren't you two going to run up against the ideals set out in Lincoln's stirring "House Divided" speech:
            "I believe this government cannot endure, permanently half slate and half free."'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
          6. seeyou | Jul 01, 2009 11:26pm | #12
            You a Dad yet?http://www.quittintime.com/      View Image
          7. User avater
            FatRoman | Jul 01, 2009 11:33pm | #13
            Not yet. Somewhere in the 7-10 day range.I will be counting on some advice from the forum of course!'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
          8. User avater
            McDesign | Jul 01, 2009 11:51pm | #14
            DW had just asked - glad it's getting close!
            Kids are usually a good deal, but ya gotta' wait so long to see how they vote.
            Forrest - still waiting
          9. User avater
            FatRoman | Jul 02, 2009 12:34am | #17
            Yep, it'll be nice to get out of beta testing and on to the real thing.Hoping she'll turn out to be a libertarian like dear old dad. If not I might have to tell her that you need to be 50 before you can vote ;)'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
          10. JeffinPA | Jun 28, 2009 03:09am | #9
            Walt
            Your projects are always so friggin interesting.
            thanks for the great picts.
            Not planning on soldering any galv metal any time soon but love the info.
            From a cost savings perspective, why wouldn't you put a fold on the sheet ends and interlock them.  Should be water proof that way.
            Jeff in PA
          11. theslateman | Jun 28, 2009 03:15am | #10
            Jeff ,
            I'm used to gutter liners / aprons all from one sheet , so this is a similar operation .
            I don't like having to lock 8 ' sheets together lengthwise over old boards . Too hard to tighten them up properly , and soldering is tougher too with a larger void if not closed tightly .
            I'd have done exactly the same on this job if it had been 20 oz . copper .
            Walter
          12. sapwood | Jul 02, 2009 12:18am | #15
            Very interesting. I have loads of questions. Can you elaborate a bit more? What kind of iron is used for this.... a big electric one or one of those heat it up with a torch kind? Can you show some photos of the soldering process? I presume the soldering is done in place and not done on the ground then brought to the roof. Right?thanks
          13. theslateman | Jul 02, 2009 12:26am | #16
            Sapwood ,
            The irons used on this project were hand held , wooden handled soldering coppers .
            The heat source was a 20 lb . propane tank fitted with a plumbers blast furnace .
            On other jobs I might use an acetylene heated iron that is constantly heated by a burner behind the iron .
            I just received word today to install a bay window roof using galvanized   -- I'll try to be more painstaking with my picture taking when I do that job next weekend .
            Heres the roof .
            Walter
          14. mikeroop | Jul 02, 2009 01:18am | #18
            so did you just run the iron down each side when you were finished lacing to get that affect? and why the edges and not the middle too? I appreciate the time you spend taking pictures and posting them. Thanks.I can learn more from pictures than most can teach.
          15. theslateman | Jul 02, 2009 01:28am | #19
            Mike ,
            Yes I flux the sides after lacing or stitching the lapped seam , and then run the iron down to dress the joint . It helps keep water from working under any small voids in the lacing process and makes a more finished look .
            You want the strength of the stitches to keep the rivetted seam watertight .
            Thanks for your interest .
            Walter
          16. seeyou | Jul 02, 2009 01:57am | #20
            Didn't you tell me solder wasn't supposed to be structural a couple of weeks ago? :^)http://www.quittintime.com/      View Image
          17. theslateman | Jul 02, 2009 02:42am | #21
            I knew you'd see you that !
            The rivetts hold the sheets together , but the thicker stithches keep that joint watertight as opposed to just sweating them together .
          18. woodway | Jul 02, 2009 03:06am | #22
            If you were doing the same operation with sheet copper, would you use rivets too or just sweat the whole seam. Also, if sweating a copper sheet rather then galv, would you use soldering copper on that too?
          19. theslateman | Jul 02, 2009 03:27am | #23
            There are three different ways I join sheets of apron depending on several factors .
            Rivetted seams in either copper or galvy , locked seams --3/4" hem on sheets facing up and down , or standing seam .
            Any of these ways work , but for this job I choose to use 8' lengths of metal . If I were locking seams I wouldn't exceed 4' and standing seam panels would be narrower than 30 " .
            You have to join the sheets somehow for a good result . Soldering a 3' sheet of lapped metal will not work well.
            Soldering coppers are my hand held soldering irons  .Copper ingots are used to form the implement .
          20. stevent1 | Jul 02, 2009 06:46pm | #24
            Walter,Thank you for this thread. It has been very informative.Chuck Slive, work, build, ...better with wood
          21. theslateman | Jul 02, 2009 11:48pm | #26
            Chuck ,
            As always you're too kind . Dino had asked in another thread if it was possible so I thought he and others might have an interest .
            Thanks again and have a great 4th Holiday .
            Best ,   Walter
          22. woodway | Jul 02, 2009 07:37pm | #25
            Gotcha, I've used soldering copper on my galv gutter. Pop rivet then soldered with your technique and it worked well. The reason I asked is sweating larger sheet goods, galv or copper, I was wondering how you joined them. I can see that attempting to join a long seam could be problematic since metal expansion, as you proceed along the seam, tends to create problems after a few inches. The 'stitching' technique you describe seems like a good method. When I did mine, I didn't use horizontal (right angle to seam) small soldered runs, just a long continuous "melt" of solder over the pop rivets and galv. sheet metal. After preliminary assembly with pop rivets, I clamped the seam with vice grip metal clamps, cleaned the seam with muratic acid then just used coiled solder and a hot copper iron to run a continuous bead of sweated solder along the joint. In my gutters, I didn't have to make long solder runs, maybe 6 to 8 inches at most but they turned out beautiful and have never leaked. I painted the interior of all the gutters with "galvigrip" paint to prevent any oxidation of the metal interior surface. After 13 years, I still don't see any rust or oxidation on any of gutters.I used a block of Ammonium Chloride (sal amoniac) to "tin" the iron ...what is your practice tinning the soldering copper???
          23. theslateman | Jul 02, 2009 11:49pm | #27
            Similar to your tinning method .
A Practical Perfect Wall
  • The New Old Colonial
