soldier course of bricks–which mud?
IdahoDon | Posted in Construction Techniques on December 8, 2008 10:16am
Architect shows a soldier course of bricks around the edge of the concrete pad being poured for a front entryway.  We blocked out a brick ledge so there is good support under the bricks.
Big question is what is the proper mortar mix for this situation to prevent separation from the main pad?  The bricks are all new.   I’m assuming a bonding agent will be applied to the pad and in the mix in place of some or all the water.
Also, does the pad have to cure a while before the bricks are applied?  The pad is 3 days old in quite cool weather so it’s still pretty green.
edit:  We’ve never used bricks before in this situation but are confident we can get the 90 bricks buttered and placed ok.
Beer was created so carpenters wouldn’t rule the world.
Edited 12/8/2008 2:18 pm ET by IdahoDon
    CapnMac | Dec 08, 2008 10:41pm | #1
    Edit:  Ok, reread your OP.
    I'd incline to latex admixtures in standard mortar mix, since this is sold with no need for weeps or the like.  But, my experience is in Texas, a local mason might steer you better for local conditions.
    Out of curiosity, is the ledge 3" deep by 8" wide or 4" x 8"?  A sailor course, showing the flat, not the edge uses a lot fewer bricks (annd allows a 3' deep ledge).  Solider coursing (edge up) gives a lot more contact between brick nad mortar, wich can be better, but it sure does cover up a lot of expensive brick.
    Edited 12/8/2008 2:50 pm by CapnMac
    1. IdahoDon | Dec 09, 2008 03:34am | #2
      The original step had the bricks with the narrow side out so we're duplicating that.
      I was surprised the original 80 year old bricks were in fine shape with great bond to the old steps.
Grout-Free Shower Panels
