Solid Surface Veneer
| Posted in General Discussion on March 12, 1999 08:22am
Can a solid surface sink bowl be blended in with a solid surface veneer countertop (to get that molded one-piece look)?
I’d like a double lav for a 54″ wide vanity made with solid surface material but the $900.00+ price (w/o install) is blowing my budget. I am hoping that the veneer would work and bring down the cost.
Phil
  1. Guest_ | Mar 06, 1999 12:30am | #1
    Can this even be done? At first blush it would seem that the current process of gluing a solid surface material, like Corian or Avonite, to a similar material basin wouldn't translate to a veneer that's, what, about an eighth of an inch thick? I wouldn't imagine the bond would have sufficient strength. There are so many attractive drop in lav basins available, I think I'd look in that direction first.
    1. Guest_ | Mar 06, 1999 01:06am | #2
      *I think I would lean with Barry on this one.Even if you were able to perfectly recess the sink so that both surfaces were flush, if and when the seal would fail, the water would penetrate and lift the veneer to make a very ugly situation.I would vote against it and use your budget money wisely and get the best combination for the buck.
      1. Guest_ | Mar 06, 1999 06:41pm | #3
        *I wouldn't try it either. In fact, I don't want to sound too negative, but even my suppliers aren't very positive about the veneers. one basically told me to stay away from it.
  2. John_F._Maxwell | Mar 07, 1999 12:23am | #4
    As I recall, Home Depot has a new display of Wilsonart solid surface veneer and they have a variety of matching drop-in solid surface sinks that look great. They are certainly worth a look. Good luck.
    1. mduval | Mar 12, 1999 08:22pm | #5
      *My parents renovated their kitchen a year ago and used the Wilsonart Solid Surface Veneer with a flush solid surface sink. They have had no problems and are very happy with the results. the Wilsonart did not come from Home Depot. While we are all calling the product a veneer, I believe that soilid surfacing isn't truly "solid". It to is mounted on a particleboard substrate. As far as the "veneer" goes, like solid surfacing, there are no visible joints. The individual pieces are joined the same way.
  3. PhillyD | Mar 12, 1999 08:22pm | #6
    I'd like a double lav for a 54" wide vanity made with solid surface material but the $900.00+ price (w/o install) is blowing my budget. I am hoping that the veneer would work and bring down the cost.
    Phil
Picture-Perfect Pergola
