Below is a crude representation of a 5V metal roofing panel.
a, b, or c would be where you would screw the panel down. Which is correct?
A case of Bud is riding on this.
“Have you seen my baseball?”
This home features dramatic interior spaces enhanced by views of the surrounding trees and stream.
The correct answer is D... hire a qualified roofer and drink the Bud while he's up on the roof.
This was a drive by roof we looked at and got in the discussion.
I was hoping for the qualified roofers opinions so I could drink my beer-----------------------------------------------------------------------------
"Have you seen my baseball?"
Abecause I said so...;)
ROFLMAOYer going to get alot of mileage out of that one, aren't you ?; )
Are we there yet ?
Have been, on and off for three months now!
He's a good sport lately though
be-eer.
drink be-eer.
be be-eer
A person with no sense of humor about themselves is fullashid
Now, I've only ever used double v-drip for porch roofs, but the answer would be, laid left to right, "B"; laid right to lelt, "A" (furthest edge of the overlap).
View ImageAdvanced Search
View ImageAdvanced Search ...BEER
Edited 6/27/2005 4:23 pm ET by razzman
I've done maybe 10 of 'em - putting the screws at 'C', as per the instructions of 'Nifftone', the metal roofing supplier -
I just knew this would end up 50/50
FYI, I used the Piffin screws recently on a interior wall I moved.
I've always enjoyed a heady debate with him,
I'll break the tie now.You are right.
Had to test his faith in me.;)
Hey, you can't change your vote!!!!!
You went from A to C.
Doesn't that require some sort of formal Taunton Magnusson Act or something?-----------------------------------------------------------------------------
Uh oh!! After more research:
Check this link out http://www.floridabuilding.org/pr/pr_detl.asp?IPT=3539&RV=0&fm=ROSrch , scroll down to the section labeled Evaluation/Test Reports Uploaded: and select the file t-3.
We shall be divided even more-----------------------------------------------------------------------------
Here is the direct link to the .pdf file, for those who do not want acrobat opening and "calling home", while they are online...http://www.floridabuilding.org/Upload/PR_Tech_Docs/PTID_3539_T_3-5V_26GaSteelOnWood_24in_EVALREPORT.pdfRight click, and choose "save as".The file is 39k in size.
Are we there yet ?
Somehow I just can't picture Piffin being AC/DC.
be sublime
naw - I'm just getting in touch with my feminin side
What was the question again?
Oh yeah...
I guess "D".
Er.. ahh...
Beer!
I gotta go.
C. with neoprene washers on the screws.
C
c but moved closer to b
3 c's will keep the snow from avelanching, avelaunching....
...from dropping on your head when you slam the door!
If top lap is @ A/B point, then C is just to right (in left edge of trough), similarly C will be @ LH side of all troughs, w/ception of first sheet down where there is one more @ RH side.
Neoprene washers to screws do not have enough, what... flexibility, thickness, resilience, ??...to sit across the top and still remain watertight.
cheers
***I'm a contractor - but I'm trying to go straight!***
A and B 30 years later to fix a leak. Bwaa!
be taking a leak
screws on ridges
nails on the flats
Witty tagline...
C..for sure.
"Viva!!! Chileo" !!!! The man with a golden heart. And a Thumbs up attitude.
