I’ve researched this on this site and have some suggestions: unfaced fiberglass, 5/8 drywall and isolate ceiling from joists. Couldn’t I just float the drywall by say gluing squares of lath every couple of feet along the joints. This should create an 1/8″ dead space barrier?
The LevelSafe Pro automatically adjusts to uneven surfaces, making it easier and safer to work with extension ladders on sloped terrain.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
Acoustic channel
You won't find it at Home Depot, but there are products to do this.
http://www.soundproofingcompany.com/soundproofing101/furring-channel-with-resilient-sound-clips/
cant float 5/8" drywall on 2' of air
kyrral wrote:
Couldn't I just float the drywall by say gluing squares of lath every couple of feet along the joints.
No. You can't just attach your drywall to the joist every couple of feet. Granted, you will reduce the transmition of vibration through the joists with these gaps of lath. But with the additional work of applying all those additional poieces of lath pieces needed to meet fastener spacing requirement of sheetrock , you'd be better off using the product Mike is suggesting.
I have also applied 1-1/2" wide x 1/4" thick foam insulation tape to framing (single sided adhesive type) to improve accousitcal damping between rooms with some success. If you don't have room for acoustical channel thickness, it can only help.
foam tape
Is that the stuff at Home depot for weather sealing or are there longer rolls available?
I order my supply here:
http://gasket-seal-foam-tape.cgrproducts.com/viewitems/sponge-strip-gasketing/1m-neoprene-sbr-blend-closed-cell-sponge-stripping?&bc=100|1002
Hat Channel
As shown in the earlier link, 'hat channel' is where you start. It's available in various depths; the thinner 1/2"stuff is fine for this use.
Also available is a drywall with a thin film within, for the express purpose of reducing sound transmission. National Gypsum calls it "Soundbreak."
Look into mineral wool instead of fiberglass. There's a high density version meant for sound attenuation. Resilient channel is available at drywall supply houses. It's pretty cheap. I spent about $120 for enough to do a 900 sq. ft. shop a couple of months ago. Also, minimize any holes in the ceiling plane, and fill them with acoustical sealant.
