Source for Plastic Caps/Washer like Grip Rite Plastic Cap
tyee | Posted in Construction Techniques on February 17, 2014 09:44am
i’m attaching 1″ foam in a crawl space.  Because of the space limitation I want to screw them on.  I need a source for the plastic caps/disks that you find on Grip Rite Plastic Cap nails.  I don’t want to buy nail with caps on them and then spend time removing the nails to get the caps/disks.
thanks
andy
  1. DanH | Feb 17, 2014 10:16pm | #1
    http://www.amazon.com/Ideal-Security-Inc-SKPHC-Plastic/dp/B005TE3C1G
    You can also search for "plaster repair washers", though they will generally be metal.
    deadnuts | Feb 18, 2014 07:07pm | #2
    EIFS washers
    EIFS plastic washers might be your best bet....
    https://www.warehousebay.com/catalog/fastening-to-wood/?osCsid=f67fc503ddec18b48158b201b76ae67d
    1. DanH | Feb 18, 2014 08:30pm | #3
      They don't appear to list washers without the nails.
        deadnuts | Feb 20, 2014 09:57pm | #5
        Yes; they do. Look under "Anchor plates only". They sell in box quantity of 500 or 1000. I buy them that way all the time. They, of course, also have a wide selection of screw lengths with the washers pre-engaged if you know your only going to do one standard thickness of insulation. I customize the washers with my own screws to increase the versatility of my stock.
    MarkH | Feb 18, 2014 10:01pm | #4
    Buy caps with 3/4" or so long
    Buy caps with 3/4" or so long nails.  Stick them into the foam and screw them down.
