Sources for PVC Trim
daen | Posted in General Discussion on May 5, 2010 01:15am
I am looking for some brand and sourcing suggestions for PVC trim. Not commonly used here in the desert southwest so I can’t find it at the big box stores.
I am looking for simple white 1x flat trim. A short list of manufacturers would be helpful and then I can do my own web research for local dealers. I just need some suggestions to get started.
Thanks in advance.
Daen
  1. calvin | May 05, 2010 06:17am | #1
    Do you have a real lumberyard in your area?
    • PVC Trimboard and Moulding Products | VERSATEX
      New VERSATEX Stealth PVC Trim Saves Soffit Installers Time and Effort: Plowed Stealth Fascia and Stealth Frieze boards accept VERSATEX soffit panels, ...
      http://www.versatex.com/ - Similar
    • Decks & Trim | Stain Resistant Decking Porch Railing Trim ...
      AZEK Building Products manufactures Stain Resistant Decks, Durable Trim, Decorative Mouldings, Long Lasting Porches, and Beautiful Railings.
      http://www.azek.com/ - Similar
    • Pvc exterior trim boards - Topix
      Has anyone used exterior trim boards made of pvc? If so what are the pros and cons of the product? I'm currently looking at Versatex ...
      http://www.topix.com/forum/home/building/T6DC6SV4O7KPOQRNS - Similar
    Shopping Results for pvc trim - shopping.aol.com
    • Jaclo PVC Bath Waste and Overflow with All Brass Trim 382SG
      $247.00
    • Jaclo PVC Bath Waste & Overflow W/ All Brass Trim 384ACU
      $257.00
    • Jaclo PVC Bath Waste & Overflow W/ All Brass Trim 384ULB
      $227.00
    • Advanced TrimWright Manufacturer of PVC Trim, Maintenance Free ...
      Advanced TrimWright manufacturers PVC exterior trim products for residential and smaller commercial buildings. Our unique product line includes seamless ...
      http://www.advancedtrimwright.com/ - Similar
    • PVC Trim - Fypon, Ltd.
      Fypon PVC Cellular Trim products can be used on both the interior and exterior of residential and commercial projects. Fypon offers boards, sheets, ...
      http://www.fypon.com/products/pvc/ - Similar
    • Kleer Trimboard - PVC Lumber - Kleer Trimboard
      Replace wood with Kleer PVC Trimboard for long lasting beauty and durability. No more painting, scraping, or caulking. Locate a Kleer Trimboard dealer ...
      http://www.kleerlumber.com/ - Similar
    • Sources - Sythetic Exterior Trim - Cellular PVC, Engineered ...
      Apr 12, 2005 ... List of web links of manufacturers of cellular PVC exterior trim materials, engineered lumber, etc.
      http://www.hammerzone.com/archives/world/products/materials/... - Similar
    • Trex Company Introduces Trex Trim(TM) Cellular PVC Trim ...
      Oct 26, 2007 ... Trex Company Introduces Trex Trim(TM) Cellular PVC Trim. - New Product Line Opens Promising New Market to Trex WINCHESTER, ...
      http://www.encyclopedia.com/doc/1G1-170276927.html - Similar
    • [PDF]
      PVC Trim
      With Fypon PVC Trim, the possibilities are endless. Fypon PVC Trim can ... all Fypon PVC Trim products are covered by a Limited Lifetime Warranty ...
      http://www.style-mark.com/literature/pdfs/catalog/fypon_pvc.... - Similar
    • Coastal Contractor: Site Report: Working with PVC Trim
      So when my supplier approached me five or six years ago with a new PVC trim product that looked like painted wood but was immune from these problems, ...
      http://www.coastalcontractor.net/article/37.html - Similar
  2. daen | May 05, 2010 09:46am | #2
    Thanks much for the great suggestions!
    I took a look at Azek last night. I used their website to find a local distributor. None in the Phoenix area.
    I look forward to taking a look at the others.
    Thanks again.
    Daen
    1. calvin | May 05, 2010 10:19am | #3
      I couldn't believe none in phoenix
      So I searched like you and found...............
      zero.
      I searched for KOMA-another good pvc brand.
      Nada.............
      within 500 miles even.
      This doesn't seem right.  Is there a strong environmental movement there?  Perhaps (and this is a stretch) there's no pvc?
      Check out Trex-I see they have a pvc trim.  Perhaps Royal also-there's is different (at least what I used) but they may have what will work for you.
      1. daen | May 18, 2010 08:43pm | #8
        Maybe the heat
        I suspect the intense heat might affect the performance. The product may behave well in other part of the country, but not worth the trouble for the manufacturers to market in the desert... A garden hose will last about a year outside around here.
        My intended use was as a simple waterproof baseboard in my shop. This will allow me to mop or lightly hose out the floor without worrying about the walls.
        Thanks to everyone else for all the great suggestions.
        Daen
  3. fingers | May 05, 2010 01:21pm | #4
    Azek is the industry leader around here.  Other brands are Kleer, Koma, Perma-Trim and I'm sure a whole host of others.  If you decide to use it just ask questions here.  It has some funny characteristics if you've only used wood in the past.
  4. fingers | May 05, 2010 01:21pm | #5
  5. max512 | May 07, 2010 10:37am | #6
    Versatex
    Azek
    Kleer
    Koma
    All of these pvc trim manufacturers. Carry the type of product you are looking for.
  6. max512 | May 07, 2010 10:44am | #7
    If you can't find any local dealers that sell the product in your area you could always see if they can place a specialty order. Versatex has done that in the past.
Mortar for Old Masonry
