Spacing of metal shims on sill
SlyGuyNS | Posted in General Discussion on January 3, 2024 04:03pm
Trying to level floors on an old home and are in middle of the process.  Expect to create a separation between sill and foundation and plan is to place metal shims and then seal them with sprayfoam.  Question is how far apart should those shims be?  I have a 14 foot section of sill that most of shimming will be within.  Assume most shims are 6 inches long x width of sill, how far apart should I be spacing them?  Shim thickness may vary along the section, not sure that matters.  Thanks.
  1. calvin | Jan 03, 2024 04:39pm | #1
    I would shim at every bolt hold down location, beam or other structural member and it would not hurt to shim under each stud location.
    Entry door location.
