Spade bits in bulk ??
baseboardking | Posted in Construction Techniques on December 25, 2003 11:30am
I am looking for 3/4″ spade bits in bulk (100) plus pieces. We do a lot of rails,hit a lot of nails-(Hey,that rhymes!.)
Thanks,happy holidays to all
Baseboard been VERRRY good to me
    Sphere | Dec 25, 2003 11:38pm | #1
    No offense but those are the EASIEST bits to resharpen..few swipes with a flat file and yer off an running. Unless you are breaking them then I would go with a milwaulkee nail eater type bit. As to where to get em in bulk ask at the bigbox store, may get a good deal. Irwin or other? Get a sh!t load at sears and return them for new ones.
    IMERC | Dec 25, 2003 11:50pm | #2
    http://www.wttool.com
    Sharpen them. Super easy to do.
    1. 4Lorn2 | Dec 28, 2003 03:15am | #3
      I agree. Sharpen them. Simple  and quick enough. You don't even need to take them out of the drill if you just want a rough job done. If you use a rat tailed file, the cutting edge is an arc, you can easily make a point on the outer edge that makes the entrance and exit holes quite clean. Ping a nail and in a few strokes you have a 'new' bit.
      1. donpapenburg | Dec 28, 2003 03:25am | #4
        Unless it turns into a twist bit . I have had a few that twisted the shank at the spade . Then it was a wobble twist spade bit .
