I want to use 2X6 T&G fir as sub/finish
flooring. The floor framing is 2X8 on 24″ centers. Joist span is 10′. Will the T&G span 24″? Do I need to put the 2X8s
on 16″ centers? There are no special loads or partition walls.
I don’t have span table for this situation.
Thanks for suggestions.
[email protected]
Understand the difference between estimating and cost planning, and don't let your sweat equity evaporate into budgeting mistakes.
Fir t+g 2X6 will span 24" no sweat. The joists are open for debate. - jb
*Ditto what Jim says. I've used 2x Fir T&G on 3' centers with no problems.
*I have long been a fan of 24" o.c. frameing. The 10 foot span will work with the right species and grade. Go to http://www.co.wake.nc.us/inspect/buildinginspections/buildinginspections.htm for span charts.
*Are you and KevinHo the same person? Relatives?
*In the Pacific North west the traditional "post and beam floor" Is constructed of 4x12 beams and 4x8 joists 4 feet on center. check local codes for spans. or call your local building inspector, that is what we pay them for.
flooring. The floor framing is 2X8 on 24" centers. Joist span is 10'. Will the T&G span 24"? Do I need to put the 2X8s
on 16" centers? There are no special loads or partition walls.
I don't have span table for this situation.
[email protected]
