Spans for 2×6 subfloor?
Gene_Davis | Posted in General Discussion on September 4, 2008 05:41am
Where are some span tables for doing open-beam floor deck construction, for which V-joint 2×6 T&G is run atop your floor beams as the subfloor?
“A stripe is just as real as a dadgummed flower.”
Gene Davis        1920-1985
  1. dovetail97128 | Sep 04, 2008 06:28pm | #1
    I can't say I have ever seen a span table for it.
    Here, where that style was quite common awhile back, 48" span was common, it did have "bounce" at 48" so some went for 32" instead.
    EDIT
    BTW : If you have never used a "Decking Puller" and are going to be laying T+G as subfloor I would recommend getting one for the job if it is of any sizable amount of sq. ft.
    Edited 9/4/2008 4:07 pm by dovetail97128
    Dinosaur | Sep 04, 2008 07:20pm | #2
    You're talking about red pine roof decking, right? Gawd almighty, why would anyone wanna use that as sub-floor?? Sand and stain it; it's gorgeous. People pay premium prices for stuff that looks and wears half as well.
    Lookit this:
    (PS--I don't have any span tables for that, either. I would say, though, that it depends on what you're gonna lay over it. For tile, I would go at 24"-30" max. For anything else or for use as the finish floor, 36" or 48" depending on what look turns the HO's crank (I'm assuming exposed joists downstairs, here).
    Dinosaur
    foolish men call Justice....
  • A Postwar Comeback
