Gentleman what is the formula for figuring out the spacing for spindles on handrailing. I’m in the old ways of cutting different spacing blocks and stepping them out untill I find the right spacing all the way from end to end.
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
Don't know about spacer blocks, or the old way...we space to code (3 15/16 here) and work out an even distance between walls or newels ...
The way I space pickets on a deck rail would work for spacing spindles as well. The pickets used are 1.5" spuare so I will explain my method using pickets and you can adjust for the spindle dimensions. I first determine how many pickets I need in a given space between posts by dividing the overall space by 5.5 (4" space + 1.5" picket). I round down to the nearest whole number to determine the number of pickets needed. I then multiply the number of pickets by 1.5 to determine the total space taken up by the pickets. I subtract this number from the overall width between posts to come up with the remaining space. This number is divided by the number of spaces between pickets which will always be the number of pickets + one. (In other words if you have 10 pickets you will have 11 spaces). The number I have come up with should be slightly less than 4. If so that is the space I will use between the pickets. If the number is higher than 4 I know that I need to add one more picket so I go back to the second step and recalculate the spaces. This may seem like alot to do but once you get used to it, it goes quick. The last thing I do is to set my combo square to the width of the space + 1.5" and use it as a gauge to layout the pickets between the posts. I am always careful to mark my X on the correct side of the line.
I hope this will help you.
Thanks for the spacing advise. Much appreciated!!
There was a lengthy discussion of this not too far back in the archive
Phill Giles
The Unionville Woodwright
Unionville, Ontario
