Spiral staircase construction
NWwill | Posted in Construction Techniques on September 20, 2005 06:29am
Ok, I need help….I am a experienced frammer and I think I have met my match. I was asked to build a spiral staircase and I need help on determining the radius on the the top-plate for the half wall. The stiar case has an inside radius of 36-1/2”. That is the size of the bottom plate but the top plate should be a bigger radius. Stair risers are 7-1/8” and treads are 10-3/4. What next?
  1. JoeBartok | Sep 22, 2005 12:23am | #1
    I don't know if this will help: Helix Calculator
    For your stairs I "back calculated" your riser/tread ratio and came up with the following entries:
    Radius = 36.5
    Height = 152.0019422
    Angle in plan = 360
    The entry for the rise is for one 360° circuit of the spiral:
    36.5 × 2 × pi × 7.125 ÷ 10.75 = 152.0019422
    Any numbers there that help?
    Joe Bartok
    Edited 9/21/2005 5:28 pm ET by JoeBartok
    Edited 9/22/2005 9:55 am ET by JoeBartok
    Edited 9/23/2005 9:33 am ET by JoeBartok
    1. NWwill | Sep 23, 2005 08:32am | #3
      Thank you,
      I think this will help.
  2. MikeFitz | Sep 22, 2005 12:26am | #2
    Two words:       Call Stan!
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
