Hello to all,
I’m thinking about adding heat pump(s) to my home in order to cool it in the summer and add supplimental heat in the winter. Can anyone recomend a brand/model or a reliable place to compare the products like another web site. Also i have radiant heat on the 2nd floor only, baseboard on the 1st, how will the heat pump work with the radiant heat? I wouldn’t want the heat pump to cause the radiant not to work properly.
Thanks in advance for the help.
KaiserRoo
The first issue is integrating the two sysyems. You will need a 2 stage thermostat and a contractor who knows how to get the heat pump t do the work when it can and kick on the electric heat when it can't.
Trane makes a pretty good system.
