We have solid wood interior doors on many of the rooms in my new-ish house, and several are separating at the joints, making the doors stick. Rainy summer has probably made it worse. I tried gluing the seams and clamping them to dry, but they have separated again. Are there any other tricks to address the issue? I was thinking of drilling them and trying to use a long wood screw, provided the wood doesn’t split. Thank you.
FHB Podcast team chats about adding Larsen trusses to an existing stud-frame home with no additional sheathing.
A Modern California Home Wrapped in Rockwool Insulation for Energy Efficiency and Fire ResistanceRelated Stories
Short of controlling the humidity in your house, long screws through the stiles and into the rails seem like a potential quick fix that's worth trying. Alternatively, you could try pocket hole screw through the rails and into the stiles - that way the screws are engaging the cross-grain of the stiles which may be a stronger joint than screwing into the end-grain of the rails.
Without completely taking the door apart and prepping all of your surfaces I don't think squeezing glue into the visible seams is going to help much.
