Spray and Batt – Basement insulation idea?
You really do not want to sandwich anything between vapor barriers.
And in general, vapor barriers for the inside of basement walls is not a great idea. (in warmer weather, basement walls will provide a path for water to enter.)
You also need to consider the temperature at the fiberglass to foam interface.
https://insulation.org/io/articles/insulation-and-temperature-a-useful-relationship/
Fluffy insulation isn't the best choice in basements. Check out this article: https://www.finehomebuilding.com/2005/03/01/the-no-mold-finished-basement
