Spray-applied, 2# polyurethane: Shrin…
| Posted in General Discussion on August 31, 2001 02:08am
Do thick installations still develop shrinkage gaps, or has the industry done something to rectify that problem?
Background: In the early days of evaluating installed, conventional, 2 lb., spray-applied, polyurethane insulation, it was common to find shrinkage gaps (e.g., 12-15% gapping) at 3.5″ studs (e.g., dislocation of the foam from the stud thereby allowing an air gap). Thus the thick installation of foam would appear to act a bit like a cake, shrinking as it cured, and pulling away from its containment. Skimcoat (0.75-1.5 inches) applications did not appear to suffer the separation cracking, perhaps because it was a thinner application.
Cameron
  1. Cameron_Duncan | Aug 31, 2001 02:08am | #1
    Background: In the early days of evaluating installed, conventional, 2 lb., spray-applied, polyurethane insulation, it was common to find shrinkage gaps (e.g., 12-15% gapping) at 3.5" studs (e.g., dislocation of the foam from the stud thereby allowing an air gap). Thus the thick installation of foam would appear to act a bit like a cake, shrinking as it cured, and pulling away from its containment. Skimcoat (0.75-1.5 inches) applications did not appear to suffer the separation cracking, perhaps because it was a thinner application.
    Cameron
Old House Air-Sealing Basics
