Spray Foam
Evan1212 | Posted in Energy, Heating & Insulation on September 2, 2010 03:31am
I am looking at an old house and the clients are interested in removing all of the plaster on the interior and spraying closed cell foam.  I am all for the energy upgrade, but my concern lies in the fact that the envelope is not water tight and any insulation we put in there will accelerate the water damage.  I feel like the best thing we can do, although not as cost effective, is to remove all of the siding, spray from the outside then put high R over that.  That would give them closer to R-19 walls with no thermal break.  I guess my question is, I know that the best was is outside in, but are they doing damage by spraying inside out.
Evan
  1. davidmeiland | Sep 02, 2010 10:56pm | #1
    If there is water
    leaking into the walls, foam insulation will accelerate any damage. I would use cellulose if I had to insulate. If you can strip and reside the building, adding flashing and a WRB at the same time, that's by far the best option.
