spray foam around windows — is it better than sealing with caulk front and back?
SoundBuild | Posted in Energy, Heating & Insulation on July 16, 2024 12:14am
I have a hard time believing that spray foam around windows is better than simply using caulk to seal the inner and outer edge of the window (with a foam backer where it’s bigger than 1/4″).
Does anyone know if Title 24 acknowledges this?
  1. stellarhomes | Jul 16, 2024 01:11pm | #1
    Spray foam around windows offers superior insulation by filling gaps completely, reducing energy loss. It forms a tight seal that prevents air leaks more effectively than caulking alone, ensuring better temperature regulation indoors. For long-term energy efficiency and improved comfort, combining both methods—caulking for initial sealing and spray foam for insulation—can provide optimal results.
  2. carpenter | Jul 25, 2024 10:31pm | #2
    The caulk might provide a good air seal n the short term — and maybe long term if it’s a good (very elastic and sticky) sealant. But, unlike foam, it won’t provide any r-value (insulation).
  3. SoundBuild | Jul 26, 2024 01:55am | #3
    I think there’s a study out there somewhere that shows dead air is as good as foam. All foam does is trap air…
Old House Air-Sealing Basics
