Spray foam insulation attic
user-7857441 | Posted in Energy, Heating & Insulation on May 25, 2021 01:44pm
I will be building a home in the northern (cold) climate and will be using spray foam insulation.   I am playing with the idea of sheathing the entire attic with 1/2″ OSB and then spraying the insulation from the underside before the drywall is installed.  Has this process been done before and are there any pitfalls with this method
    unclemike42 | May 26, 2021 06:53am | #1
    Do you mean the bottom of the attic space? Or the roof decking?
    1. user-7857441 | May 26, 2021 08:49am | #4
      The bottom of the attic space.
  2. mpergiel | May 26, 2021 08:31am | #2
    Yes, there are pitfalls.
    You can't have a composite roof over that. You need steel or similar.
    In order to reach an r45 you will need 7 inches of closed-cell foam. If your rafters are not deep enough you can strap it out and place spacers as needed.
    If you fill a 2x8 rafter space with foam you will have no room for any changes to wiring.
    1. calvin | May 26, 2021 08:47am | #3
      I’m thinking they are talking about foam between the living area ceiling and the attic floor.
      1. user-7857441 | May 26, 2021 08:53am | #5
        That is correct. Ceiling drywall, joists with spray on foam and OSB nailed to the top of the joists. Basically, an attic floor that is installed as part of the framing effort. Which would require all the trades to finish work, then spray insulation from the living area, then ceiling drywall
        1. mpergiel | May 26, 2021 10:04am | #6
          So you can use the attic for cold storage, I guess. Just build it taller is what I'd say and fill. Calculate the thermal bridging of the joists.
