Spray foam insulation on basement concrete walls.
parkjk2a | Posted in Energy, Heating & Insulation on September 6, 2016 12:15pm
If I have closed cell foam sprayed on to my basement concrete walls, do I have to frame them out first?  I’m not finishing the basement, I just need to insulate it.  The basement is only 4 feet high but I want it included in the conditioned space instead of insulating the floor of the house.  So can I get a continuous 3″ layer of foam on the walls without framing?
  1. DanH | Sep 06, 2016 01:03pm | #1
    Depending on the circumstances, the type of foam, and local codes, you may be required to cover the foam with drywall or some other fire barrier.
  2. finefinish | Sep 06, 2016 10:50pm | #2
    You do not need any framing, but as Dan mentioned you may need some type of fireproof coating.  This can be plywood, sheet metal, drywall, or a specially formulated paint on product.  If you find that your local code official insists on fireproofing the foam install, also ask around your insulation contractor about options.  I think Dow may now have a closed cell foam that is fire rated after curing.
