spray foam removal
trim123 | Posted in General Discussion on February 9, 2009 02:33am
does anyone know of anything that will remove spray foam from a bathtub? i have tried everything i can get my hands on but no luck
  1. ronbudgell | Feb 09, 2009 02:50pm | #1
    trim123
    If it's the low expansion polyurethane foam used for window sealing nd so on, then acetone.
    Ron
    1. wane | Feb 09, 2009 04:07pm | #2
      actually the only thing that will do it once cured is "mechanical abraision" .. go at it with one of those hard plastic pot scrappers ..
  2. Piffin | Feb 09, 2009 04:18pm | #3
    If this is an acrylic tub instead of cast iron, you have a problem. The same chemicals or abrasion that it will take to remove it can also damage the surface, so go carefully.
    basswood | Feb 09, 2009 04:49pm | #4
    Use Carpenter Ants. ;o)
    1. atrident | Feb 10, 2009 07:43pm | #6
        "use carpenter ants"  brilliant idea. Now if I can only figure out how to train them.
        xxPaulCPxx | Feb 10, 2009 08:05pm | #7
        Ya, it's tough.  You can only hit them on the nose with a newspaper once.
        Tu stultus esRebuilding my home in Cypress, CAAlso a CRX fanatic!
        Look, just send me to my drawer.  This whole talking-to-you thing is like double punishment.
  4. abnorm | Feb 10, 2009 05:07pm | #5
    http://liftoffinc.com/product-sealant-remover.php
Outdoor Lighting
