Spray foam vs fiberglass
FastEddie | Posted in Energy, Heating & Insulation on January 12, 2009 02:29am
The application is a 4,000 sf branch bank building.  I know very little about the different types of insulation.  Normally we use kraft paper faced fiberglass batts in the exterior walls.  The company is making noise about LEED ratings and improving the efficiency of the branches, so I’m wondering if spray foam would be a better choice.  The entire exterior of the building is sheathed in 1/2″ ply so there would be something to spray against.  How does the cost compare?
“Put your creed in your deed.”   Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.”  T. Roosevelt
    Matt | Jan 12, 2009 02:54am | #1
    Sure foam is better.  Call your insulation contractor to price it.  It might be 3x the cost.
  2. MikeSmith | Jan 12, 2009 03:01am | #2
    fast.... what are the walls  2x4....2x6...steel stud ?
    banks  have set-back thermostats...and lots of their heat loss/ heat gain is from the constant in / out
    if it were  2x4.....  i might talk to a decision maker about a mooney wall with dens-pak cellls
    1. FastEddie | Jan 12, 2009 04:08am | #3
      2x6 metal studs.  Actually the one I am about to start will be 2x8.  We have a basic automated building control system that limitsd the high and low temps.  We have double front doors that help control the air changes, but you're right that is a big factor."Put your creed in your deed."   Emerson
      1. USAnigel | Jan 12, 2009 06:12am | #4
        Steel frame work, Then go with the mooney wall to reduce thermal transfer. Install will be more the fibre glass but less than foam.
        Edited 1/11/2009 10:14 pm ET by USAnigel
Fast, Accurate Wall Framing
