Spray-foaming a Roof?
spclark | Posted in Energy, Heating & Insulation on September 15, 2016 12:16pm
Under conventional OSB/plywood sheathing under asphalt shingles, is it common practice (I’d certainly think so but that’s why I’m asking!) to leave a ventilated air space of 1″ or so between sheathing underside and top of foam?
Would there be instances (roof design) where an airspace would not be recommended?
    Mongo | Sep 20, 2016 06:37pm | #1
    either or
    You can go either way. I'd recommend you look at IRC regarding foam and roof sheathing. I want to say R804 or R805, somewhere around those sections IRC addresses foam, sheathing, vented or hot, and vapor retarders and their location.
  2. finefinish | Sep 20, 2016 10:59pm | #2
    Hi there,
          I believe the main/only reason to leave the airspace is to preserve your roof shingle warranty which may require a "vented roof assembly".  I don't think any roof warranty is worth much of anything to be honest.  I would eliminate the air space and foam the underside of the roof sheathing for an unvented assembly.  This is not only common, but I would say, it is now the most common way roofs are insulated in my climate zone 5.  The point of a vented roof is to allow cold winter air in to keep the underside of the roof sheathing cold so snow on the roof doesn't melt, then re-freeze at the (cold) eaves overhang causing ice dams.  A properly foamed unvented roof will prevent warm inside air from ever reaching the underside of the roof sheathing, so there is little chance of ice dams.
      spclark | Sep 23, 2016 09:21am | #3
      Thanks FF!
      Your logic follows my thinking too. Mongo I'll look into those relevant IRC sections as you suggest.
  3. DanH | Sep 23, 2016 01:41pm | #4
    From a practical standpoint, a 1-inch "ventillated" air space might as well not be there.  It serves as a mouse run but not much else, since very little air will flow (especially after leaves clog the vents).
