Spriral Stair-to-Deck Connection
Rockford | Posted in General Discussion on April 9, 2007 08:35am
OK, we’re finally ready to get quotes on the exterior spiral staircase that’s going from the upstairs balcony to the roof-top deck.  The balconly was engineered with a giant beam that spans the house and cantelevers out right under where the center of the spiral should land.  There’s also additional 4X blocking and strapping right where the center post of the stairs would hit the balcony, so structural support is not the concern.
I’m really worried about water-proofing the connection point at the balcony.  First, the balcony and deck material is a built-up system of diamond lath, latex-modified mortor, fiberglass mat, resin, troweled-on texture and then a color coat- they call it “Ultra-Flex 2000”.
What’s the best way to seal the spiral’s base plate to the balcony surface?  I’m assuming I’m going to drill through the deck for the lag bolts, so that’s where I’m concerned.  I’m affraid that even if I used the best marine sealant (3M 5200) it would eventually dry out and the tiniest crack would allow water penetration.
Would it be possible to not fasten it at the bottom and just set it in a bed of sealant and let the weight of the stair do the work?  Of course it would be fastened at the top though.
Any thoughts or experience?
Thanks!
  1. Brian | Apr 10, 2007 04:30am | #1
    thoughts...
    Its hard to picture the detail where this would happen - I am thinking the bolts should be coated in silicon or tar etc...
    But I am wondering if there is a way to flash over the detail, or weld a bracket such that the attachment points would be under the waterproof deck.
    Finally, could the mesh and ultraflex 2K go over the attachment plate?
    Treat every person you meet like you will know them the rest of your life - you just might!
  2. ponytl | Apr 10, 2007 05:16am | #2
    if it's secured at the top... i don't see an issue with it sitting in a bed of sealant...  the bigger the base plate the better 16" sq min i'd think.... with 20" being better... not like it's going anywhere....
    jmho
    p
Grout-Free Shower Panels
