squash blocks
| Posted in General Discussion on April 3, 2000 03:10am
It is my opinion that squash blocks are required at bearing walls (using wood I-Joists), but my builder says they are not needed. Who is correct?
  1. Guest_ | Apr 02, 2000 10:17pm | #1
    They are required as far as I know. Ask your engineer or architect if your not sure.
    1. Guest_ | Apr 02, 2000 10:56pm | #2
      *Garry, For the brand of "I" joist we use squash blocks are rarely required. A few of the instances center around tranfering concentrated loads. Load bearing walls would requre them if they weren't along the rim joist. Find a copy of the instalation instructions. A copy typically comes with the floor system. There's a copy on the net to I bet. Opinions, mine included, don't count for much with engineered wood. The "I" joist company has already studied what's necessary.Chase
  2. FramerPa_ | Apr 03, 2000 02:54am | #3
    Squash blocks are a must, no matter what type of floor joists are being used. The purpose of squash blocks is to carry a bearing post or jack that falls between the joists. "Between" is the key word here, which means squash blocks have nothing to do with the joists. Example : A 6ft. archway in the bearing wall at the first floor. If the jacks for this opening are between 2 floor joists , a squash block is a must to carry the load of the jacks. Otherwise the load is bearing on the floor plywood only. Hope this cleared up your concerns.
  3. Guest_ | Apr 03, 2000 03:05am | #4
    Squash blocks or some kind of blocking are typically required only where there is a bearing wall
    b above
    the I-joists. You don't specify whether you're talking about stacked load bearing walls, or a load bearing wall
    b below the I-joists.
    When in doubt, ask the supplier of the I-joists for their documentation. That should be the final answer.
  4. Garry_Clark | Apr 03, 2000 03:10am | #5
