Squeaking door hinges
Jeff_Clarke | Posted in General Discussion on November 9, 2007 05:16am
May seem like obvious questions:
What makes hinges squeak?
How do you adjust the squeaks out?   (lube vs. bend/align etc.)
Condition is 6′-8″ 2-panel doors with 2 high-quality (Baldwin solid brass) hinges/leaf
PS – I’m not going to add a third hinge/leaf
  1. BungalowJeff | Nov 09, 2007 06:34pm | #1
    I just use a drop or two of some good ol' 3-in-1 oil from a can that has to be 30+ years old.
    ...that's not a mistake, it's rustic
  2. DonCanDo | Nov 09, 2007 08:56pm | #2
    Remove the door and check that the knuckles are aligned.  If they're not, file down the high spots.  The point is that all of the hinge knuckles should carry equal weight.
    Replacing the hinges with brass (or even brass-plated) should also work because brass is softer than steel.
      Jeff_Clarke | Nov 09, 2007 09:03pm | #3
      They are Baldwin solid brass
      1. doorboy | Nov 10, 2007 12:47am | #4
        Baldwin IS high quality. However, two solid brass hinges on a heavy door may not be enough. A third hinge would balance out the torque and maybe help them last longer, but since that's out of the question, I think I'd go with brass plated steel hinges--maybe even ball-bearing."She wrote a long letter, on a short piece of paper." Traveling Wilburys
        1. Dave45 | Nov 10, 2007 03:53am | #5
          I recently began hearing squeaking on my kitchen cabinet doors - after 10 years of silent operation.  One day, I noticed that my 88 year old MIL was bracing herself on the door when she went into a lower cabinet.
          A quick spritz of WD-40 fixed that. (Although I was tempted, I spritzed the hinges, not my MIL - lol)
          JDRHI | Nov 10, 2007 03:57am | #6
          Good suggestion....why is it out of the question?
          J. D. ReynoldsHome Improvements
            Jeff_Clarke | Nov 10, 2007 06:06am | #7
            All the doors in the house have 2 hinges / leaf - I don't want to go changing that for 28 doors.   Besides the door in question is a 2'-4" x 6'-8" 2-panel and not all that heavy.
            Personally, I think that the deal is they came off a couple of times for undercutting/planing and it's very easy to bend the knuckles out of fit when removing the door.   I think that's why it's noisy
            Edited 11/9/2007 10:07 pm ET by Jeff_Clarke
          2. gordsco | Nov 10, 2007 02:17pm | #9
            Pull the pin and smear lightly with white lithium grease.
            Return pin and wipe off any excess.
            Fogetaboudit.
          3. DanH | Nov 10, 2007 03:51pm | #10
            Don't forget to hold the handle in tight until you get the pin back in.
          4. gordsco | Nov 10, 2007 04:49pm | #11
            I use white lithium grease so when I hold the pin in my teeth, the stains aren't as noticable
            Gord
  3. DanH | Nov 10, 2007 07:04am | #8
    Mice.
    IMERC | Nov 18, 2007 06:08am | #12
    dry metal to dry metal...
    use bar soap instead of oil to lube...
    WOW!!! What a Ride!
      Jeff_Clarke | Nov 18, 2007 06:26am | #13
      How about the paraffin wax block that I use to start screws?Jeff
        IMERC | Nov 18, 2007 07:51am | #14
        that too..
      2. DougU | Nov 18, 2007 04:33pm | #15
        Thats actually better. Sometimes soap has enough moisture(water) in it to cause rust.
        Edited 11/18/2007 8:34 am ET by DougU
          IMERC | Nov 19, 2007 05:08am | #17
          are you saying those aren't real brass hinges????
            Jeff_Clarke | Nov 19, 2007 05:10am | #18
            If my Baldwin brass hinges start rusting I'll be very surprised ;o)Jeff
            IMERC | Nov 19, 2007 05:16am | #19
            if they came from china...
            expect them to...
          3. MikeHennessy | Nov 19, 2007 03:22pm | #23
            "if they came from china...
            expect them to..."
            Nah. Lead don't rust.
            Mike HennessyPittsburgh, PA
          4. DanH | Nov 19, 2007 03:40pm | #24
            Actually, there was a segment on NPR recently about the lead problem in China. They put lead in everything, since it's a cheap, easily-worked "filler" metal. Where others would use zinc, they use lead.Wouldn't be at all surprised if Chinese "brass" hinges are high lead and thus poor quality.
          5. MikeHennessy | Nov 19, 2007 03:45pm | #25
            Yeah, I first typed that in jest, and then I got to thinkin' . . . .
            Hmm.
            Don't let the kids chew on the hinges!
            Jeff_Clarke | Nov 19, 2007 06:51pm | #26
            They are Baldwin, not Bardwin.
          7. DanH | Nov 19, 2007 06:52pm | #27
            That's how YOU pronounce it.
          8. User avater
            IMERC | Nov 19, 2007 07:39pm | #29
            no wonder the start sagging so soon...
          9. DougU | Nov 19, 2007 06:09am | #20
            Hell I dont know!
            Where you been? I dont think I have seen your name on here in several months
          10. User avater
            IMERC | Nov 19, 2007 06:16am | #21
            went fishing...
            trashed the computer...
            went fishing...
            just got a new one...
            celibrated by going fishing...
            stopped in saw G8 up at his mountain place...
            saw he was insulating and hanging rock...
            beat feet and went fishing...
            found a place on the Arkansas...
            the fishing is some of the best I've ever found...
            so I went finshing...
            be back there the rest of the week..
            Heck and G8 are suppose to meet me there later this week..
            so I'll fish till they show up..
            how you been???
          11. DougU | Nov 19, 2007 03:08pm | #22
            Smart man!
            So, got a little fishing in huh
            Everythings been good, no time to fish but then again, if there was I'd probably do something else!
            Working on a lake house and I see fishermen all day long, does  that count? Apparently  the walleye are biting.
          12. User avater
            IMERC | Nov 19, 2007 07:36pm | #28
            sure... we can give ya an E fer effort...
  5. DanH | Nov 18, 2007 04:46pm | #16
    If the hinges squeek, the doors are too heavy for the hinges, the hinges are poor quality, or they need a touch of lube.
    Hit them with just a TOUCH of Teflon spray (eg, TriFlow), and if that doesn't do the job well then change out the hinges for ball-bearing ones, or at least ones with separate thrust bushings.
    Another thing you COULD do, if you're a glutton for punishment, is grind down the ears enough to slip a couple of bronze washers into each hinge (DIY thrust bushings), positioned so that the weight bears on the bronze.
