Have problem with squeeky hardwood floor. Owner does not like the idea of drilling hole and breaking off screw as with carpeting. Can I fix this problem from underneath in the basement ceiling…………….
![](https://images.finehomebuilding.com/app/uploads/2024/07/09110145/01232520-hybrid-powered-router-thumb-16x9.jpeg)
Metabo HPT's dual-powered plunge router offers the option to plug in an otherwise-battery-operated tool for production work.
Thin strip floor or full 3/4?
*Maybe placeing shims from underneath
*David, First you need to identify the location of the squeaks. Is it coming from the hardwood flooring or from the sub floor? Is it a localized squeak, ie one spot only or does it follow you as one walks across the floor? Is there floor underlay paper between the floor and subfloor?walk gooddavid
