What can be done with a house with square edged plywood subflooring and no blocking installed at the long seams. The plywood seems to go up and down between joists without either blocking or T&G edges. It also has more squeeks than normal despite being glued down (with nails).
Any comments or suggestions would be appreciated.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
What can be done with a house with square edged plywood subflooring and no blocking installed at the long seams. The plywood seems to go up and down between joists without either blocking or T&G edges. It also has more squeeks than normal despite being glued down (with nails). Any comments or suggestions would be appreciated.
