Stacked cabinets – sit on anything?
edwardh1 | Posted in Construction Techniques on September 11, 2009 05:30am
We are putting a “stacked” cabinet on a bathroom granite countertop. The cabinet is a wall unit, and will be on the granite.
Is there any way to keep splashed water from wicking up the cabinet’s wood. Seems like a gasket / something to raise the cabinets wood above the granite about 1/8 inch is needed between the cabinet bottom and the granite – what is standard practice here?
  1. JMadson | Sep 11, 2009 08:12am | #1
    Can it be fastened to the wall?
    What about putting it right on the granite and putting down a thin bead of matching caulk?
      PeterJ | Sep 11, 2009 10:43am | #2
      This is a pet peeve of mine. The cabinet surface ajacent the sink is the least durable between c'top and backsplash and can potentially look like poo after many cleanings...depends somewhat on type of finish and cleaning regimen. Can the backsplash wrapped onto cab side?
      If I had to do without backsplash, I'd run a SKINNY bead of Alex Plus clear at cab/c'top intersection.
Grout-Free Shower Panels
  • A Grand Rescue on the Coast
