Stage Risers
chickenfarmer | Posted in Construction Techniques on September 12, 2005 03:44am
I got roped into building some risers for a local orchestra.  Nothing fancy, just 4′ x8′ boxes maybe 9″ high.  I was planning on using #2 pine for the “joists” maybe 12″ on center running the long way on the sheet of plywood with maybe a bit of blocking to lessen the chance of collapse.
They should be safe, fairly light, and not too costly when it comes to materials.  Any ideas?  How thin a piece of plywood can I get away with?  I might be able to buy the 1×10 pine rough cut at a local saw mill to save $.
Thanks for the suggestions.
  1. MikeSmith | Sep 12, 2005 04:03pm | #1
    tell them to have a bake sale and buy the commercial ones.. they'll last forever.. and no liability on you
    we have an 80 member chorus... we have (5) 3-riser sections.. they even have wheels
    reminds me... tonite is the first rehearsal for the Christmas concert
    thanks for the reminder...
    supposed to have 5 or 6 combined chorus with about  300 people  total
  2. FastEddie | Sep 12, 2005 04:49pm | #2
    1x is a little thin for the joists.  I would use 2x8 with 3/4 ply for the sheathing, which would make a 8" riser, just on the limit of a step.  If you us 2x10, it will be a bit of a stretch to step up on it.  And I would run the joists the short way.
    If you don't do something to fill the void between the joists, it will make for a hollow drum sound with every step.
    Go with the bake sale and buy commercial risers.
Fast, Accurate Wall Framing
