I am in the process of having a new home built and purchased custom curved oak stairs. The builder did not properly cover the stairs after they were installed. They are dirty, grimy and there are a few areas where they are stained from being wet and a few areas where spackling was left on them. Please help. Will simple sanding clean them up prior to the application of a clear stain? Will they have to be chemically treated/bleached??? Please help. Thanks. Steve [email protected]
Stephen, It is hard to say without actually seeing the stairs but sanding may work. The spackle should come off easily with a putty knife. Vacuum the stairs well to remove any sand and/or grit- sanding with dirt/ grit will only make it worse. If the grime is severe, you can wash the stairs with a mild solution of Murphy's Oil Soap using a DAMP, not wet, sponge. Let it dry thoroughly before sanding. The last resort is bleaching (oxalic acid). Good luck.
*god almighty stephen, get your builder to clean it up and make sure you don't pay him for it. what's he drive?
*Ditto Calvin. That guy won't be winning any FHB awards!
I've built and finished a lot of stairs,and have not seen any stains that won't sand out except for greasy food stains.Don't let your guys eat lunch on the stairs or near any unfinished stain-grade wood.
