Staining a structure that used to be painted
![](https://secure.gravatar.com/avatar/39be41fea646e8317e1b3d48841ce33f?s=52&d=https%3A%2F%2Fimages.finehomebuilding.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Am I able to stain this as it sits or would I have to remove all the remaining paint from the front?
Construct the intersecting gable on the main roof for a faster, easier-to-build assembly.
While I'm mainly a fine woodworker I'll go ahead and speak out here from experience in what I've observed relevant to the particular oil-latex solid stain to which you are referring.
What appears essential is the preparation in making certain that the wood surface is entirely clear of any prior coverings to include paint, stain and even weathering effects that contain mold or mildew deep in the wood fibers. There are products available to effectively remove all such factors, the absence of doing so before stain application results in what I would characterize as a mottled appearance of the oil-latex stain as a result of variable absorption that apparently cannot be corrected by multiple applications because the mottled effects seem to persist and are unable to be chased out.
So adequate time spent on preparation results in a trouble-free stain application and satisfying outcome regarding the product mentioned and, very frankly, is essential regarding stain and paint products in general.
Thanks for the reply. I figured that was going to be the response. It's not worth the effort; this is a 100 year old building. I will just repaint it white as it was.
---RWR
I would recommend a water based solid color stain. This will soak into the wood instead of sitting on the surface. Sometimes this can be a one coat operation, and to redo in 15 years give it a power wash and skip scraping loose flakey paint.
try to remove the soft, oxidized wood and loose paint. Oil dries more slowly so it penetrates a bit more and makes a good first coat. Water based holds color better and is less messy so it is best for final coats.
