Staining Cedar Siding in Cold Weather
| Posted in General Discussion on November 19, 2002 10:43am
I want to stain the cedar channel siding on my house with Benjamin Moore Moorewood Alkyd Solid Stain. On the stain can it say’s not to use under 50 degrees. The average temperature is in the mid 40’s. Has anyone used this stain under 50 degrees? What will happen if I do? Is there anything else I could use in cold weather? Thanks for the advice.
  1. GClancy | Nov 19, 2002 10:56pm | #1
    If it says on the label Do Not use under 50 degrees, take that wisdom to heart.  Put the brushes away, curl up on the couch and watch the Patriots.  Wait till spring time, the siding will still be there.
    GC
    Qtrmeg | Nov 20, 2002 01:09am | #2
    If you have to, thin so it works, don't expect much over the wet spots.
  3. Piffin | Nov 20, 2002 02:39am | #3
    If this is a water based stain, make sure it gets warmer first. If oil, it'll just cure more slowly.
    Last fall, I succumbed to the tempatation to use a water based solid when it was 50° top temp of the day with dropping to 38° later on. Wanted to hurry and finish to get paid.
    I ended up resanding and repainting that railing for free this spring.
    "The first rule is to keep an untroubled spirit. The second is to look things in the face and know them for what they are." --Marcus Aurelius
