I will be installing some Marvin wood (Mahogany interior & exterior) windows and wondered wether I should apply the stain before or after installation? I will also be installing some Mahogany trim elsewhere which requires a penetrating stain. Same question, should I stain it before it is installed or after?
They will get pretty dirty during construction and there will be sheetrock dust. No sense staining now only to have to do extra clean up later.
There is more than one way to do this, of course.
My preferred method is to stain/topcoat after installation. That allows me to use the same stain and topcoat on the nail hole filler as everywhere else. I just think it gives me the best results. There's no interruption in the sheen of the topcoat due to the nail holes, etc.
Regarding the trim, one "trick" I have is to paint the walls before the trim goes on. Then I apply some masking paper where the trim will go, allowing it to run about 3" outboard of the eventual trim location. In this way, I can be sloppy with the stain and topcoat when finishing the trim. When it's all done and dry, I use a new razor knife (or Xacto) to cut away the paper.
Edited 5/25/2007 1:06 am ET by Ragnar17
I'm going to be the contrarian here and say that you should apply your stain & at least one top coat to windows and trim before installation. The material will be protected from grubby fingers, and you should just need a light sanding before your final topcoat. Less cutting in, more control of the process.
It's always worked for me.
That's what i do too, nothing contrarian about that. Whatever works given once's situation.
