Stainless finish repair
wolf | Posted in General Discussion on August 27, 2007 04:28am
I was wondering if anyone had advice on removing some scrub marks from a stainless cooktop. The wife tried removing a stubburn stain by using some SOS or other abrasive cleaner and now there are 2 quarter sized unpolished spots there.
I was going to try some white rouge on a 3-4″ cotton wheel or a smaller pad on a Dremel tool. If there are any ideas or techniques out there I’d appreciate the input.  Thanks
  1. DanH | Aug 27, 2007 04:30am | #1
    Just work the whole thing over with the same cleaner.
    1. DanH | Aug 27, 2007 03:47pm | #3
      Bit of a gripe here. Folks buy stainless steel but fail to appreciate one of its beauties: As it's used and cleaned it acquires a patina of tiny scratches that is really quite attractive. Trying to keep it mirror-shiny is like polishing your copper roof.
      1. onder | Aug 27, 2007 04:20pm | #4
        Yeah, but what about sinks? Hard water has made
        mine look pretty tatty. They arent mirror
        bright when new (mine is a budget model) but
        what is the best way to make it look presentable?
        I tried the wire wheel on a drill. Better but not
        by much.Comments?
        1. DanH | Aug 27, 2007 04:53pm | #5
          Unfortunately, the cheap stainless sinks don't polish up real well -- must be the type of steel used. But in any case the best approach is to always use steel wool (either plain or something like SOS pads) when cleaning. This will result in a much more uniform patina than you get with scouring powder.Never use an acid drain cleaner on stainless -- the acid can badly pit the surface.
            PaulBinCT | Aug 27, 2007 07:59pm | #6
            Noooo... neverrrrr use steel wool on a stainless steel surface. I used to own a large photo lab with stainless steel all over the place. Every manufacturer advises against it as small particles of steel will get into the surface and cause rust and pitting.PaulB
          2. DanH | Aug 27, 2007 08:31pm | #7
            Well, all I can do is speak from experience. You wouldn't want it in a photo lab because the iron could cause spotting and other problems with the chemicals, obviously.
            PaulBinCT | Aug 27, 2007 08:40pm | #8
            From a manufacturer's website:
            "Do not use ordinary steel wool - iron particles can become embedded in stainless steel and cause further surface problems. Stainless steel and "Scotch-brite" scouring pads are satisfactory"
            From a trade association: "Wire wool pads made of "ordinary" steel (e.g.Brillo pads) are totally unsuitable for stainless steel as they will impair the self-healing capability of the stainless steel surfaces"
            Anywayyyyyyyyyyy... your stuff, clean it as you will ;)PaulB
          4. DanH | Aug 27, 2007 08:58pm | #9
            Like I said, there's cheap stuff and there's good stuff. The good stuff won't mind.
          5. DoRight | Aug 28, 2007 07:45pm | #20
            Dan, you say "... must be the type of steel used."
            Stainless steel is not made of steel.  Get a magnet and see for yourself.
          6. DanH | Aug 28, 2007 07:56pm | #21
            The lack of magnetic attraction does not prove an absence of iron. Stainless steel is indeed an alloy consisting primarily of iron and chromium, with enough carbon to qualify as "steel".
          7. KenHill3 | Aug 28, 2007 08:21pm | #22
            I do recall that some stainless I have worked with was indeed magnetic, albeit weak. Different grades of SS. Someone said that magnetism in SS was caused by work-hardening(????).Yes, most quality sinks have a 'brushed' finish. I have done a brushed finish on raw SS stock, and I used a reciprocating (straight-line) sander- in fact it was my Porter Cable profile sander that I used. Geez, I think that was one of only a few times that sander has ever been employed- for the most part a useless tool.Oh, and Dan, I believe that nickel is also alloyed into the mix, could be wrong, tho.
            Edited 8/28/2007 1:24 pm by kenhill3
          8. DanH | Aug 28, 2007 08:37pm | #23
            Nickle is commonly added to the SS used for bolts and the like to reduce spalling. There are maybe 50 different standard alloys of stainless.
          9. DoRight | Aug 29, 2007 07:35am | #28
            Sorry, it is not steel.  SOrry.
          10. DanH | Aug 29, 2007 02:28pm | #29
            You're right, you are.
  2. misfit | Aug 27, 2007 02:44pm | #2
    find some Blue Magic in the tube. it works miracles
    http://www.mas-parts.com/cart/bluemagic.html
  3. TomT226 | Aug 28, 2007 02:21am | #10
    "Barkeepers" cleaner, and a Scotchbrite pad.  Work it all over.
  4. sapwood | Aug 28, 2007 02:37am | #11
    Since you're talking about POLISHED stainless, the cotton buff and compound is a good way to go. The pad that she used was courser than whatever they used to get the polish. She put minute scratches onto the surface. You have to use progressivily finer media to regain the original look.
    As others said, you will have to work the surrounding area to blend in the new work. Use only the nylon type of abrasive pad on the stainless. Steel wool should be avoided like the plague.
    My wife got some cleaning cloths called Miracle Cloth. These are a synthetic material that work wonders on stainless. They won't restore a scratch, but for everyday cleaning and spiffing up, they are great.
    james | Aug 28, 2007 05:21am | #12
    am I the only one who sees the irony here-
    now I know how to remove her scratches but how do you get a stain in a stainless top>>>>:)
    and now for some usefull content...
    what others have said about fiish restoraton... obviously the abrasive your wife used was too corse.. now you have to start using finer and finer abrasives to remove the scratches. I would start with some 600G wet and dry.. then 800.. then 1000.... then 1200... if you have not reached the shine of the surrounding metal you can go up to 1500 then start with the compounding, Heavy, medium, fine.. then swirl remover... then polish. It really depends on the original finish and quality of the material.
    james
    1. KenHill3 | Aug 28, 2007 05:42am | #13
      Stainless steel wool.
        xxPaulCPxx | Aug 28, 2007 09:50pm | #24
        It's sheared from only the cleanest metal sheep.Rebuilding my home in Cypress, CA
        Also a CRX fanatic!
        Oh, good Lord, no. But I can give him two dollars and an assault rifle.
    2. DanH | Aug 28, 2007 05:49am | #14
      And then pick an abrasive (powder, steel wool, whatever) and stick with it. Eventually the whole surface will have the same patina.
        james | Aug 28, 2007 06:35am | #15
        steping abrasives just makes the whole process faster..... thats why you don't start with 220G paper to remove saw kerfsmarks on a board. sure it will eventually get the scratches out but it sure will take a while.
        when working with metal or stone the difference is more pronounced.. the finer grit erases the corser grit and so on.. untill you reach polishing grits, which are really only super fine abrasives.
        now if the stainless wool matches the final finish of the whole stove then bobs yer uncle.
        james
        1. DanH | Aug 28, 2007 03:20pm | #16
          What I'm saying is don't step, just stick with one size. Everything will look the same eventually.Stainless steel isn't supposed to look polished.
            james | Aug 28, 2007 05:19pm | #17
            I understand what you are saying about stove tops etc but don't tell the hot rod guys that stainless isn't supposed to be polished :)
            james
          2. DanH | Aug 28, 2007 05:30pm | #18
            Well that's a diffent thing entirely, of course. But sinks and stoves and other appliances where stainless is used for it's ability to be easily cleaned are not intended to have a mirror finish. In fact, you can tell a poor quality SS sink by it's shiny appearance in the showroom -- better quality units will have a matte finish.
    3. DoRight | Aug 28, 2007 07:42pm | #19
      Stainless Steel, ani't stainless and, surprise!, it ani't steel!
        james | Aug 29, 2007 04:16am | #27
        yes I get it.. stainless is an iron alloy though... I can buy "magnetic stainless" or get grades that have no magnetic attraction. I have worked with bar, hex, sheet and plate SS extensively for residential/commercial work as well as automotive/motorcycle restoration so ( while not a metallurgist) I know a bit about the material.
        I also know that most grades of appliances come with a brush finish but I have seen more and more of the polish finish stuff and all I can say is I don't like it... would rather have chrome as it is a harder material.
        magnetism has nothing to do with work hardening, its either there or it is not.
        800G wet and dry dose a good job of replicating most "brush finishes" but some are finer... some are coarser.
        I should have been more clear about the process I listed as that is what I use to remove scratches ( read gouges etc from an errant tool bring drooped in a sink for example).
        oh well.. I was never a fan of re texturing an entire surface if I have the materials/tools to replicate it in a small area very quickly.
        regards
        james
    4. myhomereno | Aug 29, 2007 09:20pm | #30
      "I would start with some 600G wet and dry.. then 800.. then 1000.... then 1200... if you have not reached the shine of the surrounding metal you can go up to 1500 then start with the compounding, Heavy, medium, fine.. then swirl remover... then polish."It sounds as when you are sanding out the orange peel on a car.
      But I agree with you, this is the only way to get the shine back.It makes me laugh when I hear people talking about their "DREMEL", it seems like the clueless home owner's magic tool.Martin
        james | Aug 30, 2007 06:02am | #32
        Well if I was sanding out OP on a car I would start with 400G maybe 220, are we talking about a "peeled" base coat"?
        If that was the case i woul start as noted earlier.. then work up to maybe 800G then apply another coat of paint ( base coat ) with a blending additive to "melt into " the surrounding area.. let sit for a bit ( per manufacturers recomendaitons) the apply clear, then block out with 800-1200G then start compounding..
        same basic idea but automotive paint is much softer than metal... I sure miss enamel laquor where you didn't have to buff anything if you were good!!!!
        james
        1. Talisker2 | Aug 30, 2007 06:38am | #33
          I have found another use for my Fine MM, I use the polishing pad with "Mothers" wheel polish, seems to cut the baked on crud off. It will leave a highly polished area if you get carried away.  I expect in a few years I will completely disasemble the entire cooktop and refinish it correctly as there are a few areas close to the burners that it is impossable to clean completly.
          JF
        2. myhomereno | Aug 30, 2007 07:01am | #34
          "Well if I was sanding out OP on a car I would start with 400G maybe 220, are we talking about a "peeled" base coat"?"Good luck sanding out 220 or 400 Grid sand scratches without sanding thru the final coat.
          But that's another story and we are not detailing cars here on the forum (which is good, there are to many detailers on this planet without sufficient knowledge and skills)Martin
  6. woodway | Aug 29, 2007 01:06am | #25
    Belt sander with 220 grit open cut belt.
  7. JeffinPA | Aug 29, 2007 01:30am | #26
    I am with DanH.
    I have always just scrubbed the whole thing down with the same SOS pad.
    It is important to run the pad by hand along the same lines as the origonal graining in the brushed stainless steel.
    If it is high polished, then polish, but most are brushed unless they are high end.
    Good Luck
  8. User avater
    PeteDraganic | Aug 30, 2007 05:29am | #31
    You will have to polish the surface in stages to make it shine again.
    I've polished clear surfaces such as epoxies and plastics, which are the most difficult surfaces to polish so that they don't show imperfections.
    You can start wetsanding with 600 grit sandpaper, then 1000 grit, then maybe even 1500 grit, then rubbing compund then polishing compound.  It is a process but it works.
    Now, technically, you can do all this with only polishing compound but it would take a hundred times longer to work away the scratches.
    Think about this, they can polish lenses to a crystal clear finish... so you can polish your stove too.
    http://www.petedraganic.com/
