Stainless Steel Backsplash?
| Posted in General Discussion on February 18, 2000 10:29am
Any suggestions on what to use and how to install a brushed stainless steel backsplash all the way up to the bottom of the cupboards for a kitchen remodel? That’s what the customer wants…never installed one.
Thanks,
Jerry P.
  1. Guest_ | Feb 16, 2000 09:33pm | #1
    Jerry;
    We remodel restaurants, and frequently we are asked to cover wall surfaces with stainless steel panels. The same techniques for full walls will work with a backsplash, assuming the cabinets/tops are not already installed; using a 20ga or 22ga stainless steel sheet apply full coverage construction adhesive to the back, and then press to the wall, pull from the wall to "breathe" then repress, and roll out using a laminate roller.
    I would size the sheets approximately 2" taller than the areas that need to be covered so that your upper cabinets and lower countertops will cover any edges. The lengths of the sheets need to be cut exactly to your wall dimensions, and inside/outside corners can be covered with moldings broken from stainless steel and attached with clear silicone.
    To finish you can caulk any voids using either clear or aluminum colored silicone caulking.
    1. Guest_ | Feb 18, 2000 10:29am | #3
      *Call your laminate supplier and ask for a chain of formica's metal laminates.You then apply them just like a laminate backsplash.Lots, about 40, last I checked, variations.Dave
  2. Jerry_Peterson | Feb 18, 2000 10:29am | #2
    Any suggestions on what to use and how to install a brushed stainless steel backsplash all the way up to the bottom of the cupboards for a kitchen remodel? That's what the customer wants...never installed one.
    Thanks,
    Jerry P.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
