Stainless steel finish nails for decks
dedhed | Posted in General Discussion on May 11, 2007 02:24am
I saw on an episode of This Old House , Tom Silva nailing down Ipe with a Senco 15 gauge finish gun. Is this a doable option or should I just stick to SS trim heads? I already am familiar with all the under deck options and am not interested.
  1. dustinf | May 11, 2007 03:39am | #1
    I'm pretty sure if you nail it down with finish nails, you have to use an adhesive also.
    http://www.manasquanfasteners.com is a good source for the nails.
    Glamorous
  2. woodguy99 | May 11, 2007 04:48am | #2
    I made the mistake of doing that once.  Never again.  Within two years all the nails had worked their way out.  You need a nail with a deformed shank, like a ring shank, or just use screws.
    Are you sure Tommy wasn't using a siding nailer?
    DDay | May 11, 2007 05:07am | #3
    He used SS finish nails and 3m marine adhesive. You are correct, he used a senco finish nailer, the older style, it was definitely not a siding nailer. finish nails will go into Ipe fine, I've never tried siding nails but doubt they would.
  4. RobWes | May 11, 2007 03:28pm | #4
    Not a good plan. We have a huge mahogany deck and every year nails get pulled and replaced by SS trim head screws. It would have been cheaper to do it right the first time. Some builders.....
A Practical Perfect Wall
  • The New Old Colonial
