Stainproof Tile Grout
| Posted in General Discussion on June 21, 2005 07:49am
Saw this stuff raved about in July issue.  Be careful if you try it!  I talked a customer into it and am sorry I did!
Simple layout w/12″ tiles & 1/4″ grout lines.  Installed as usual, which was not in conflict with instructions.  Tough to clean off!  Worse, arrived next day & it all shrunk and cracked.  Thought I’d have to saw it out & re-apply, but called manufacturer first.  They admitted to “a few issues with cracking”, but said I probably used too much water at clean-up.  (Not likely.)  On a hunch I called back & got another person.  She suspected I got too much air it it!
Both said all I had to do was re-apply over the cracked stuff; no big deal.  Only it is a big deal!  I need twice as much of this very expensive “grout?” and have to invest another day or 2!
This may work for a home owner who doesn’t care about his time and it may work to go over old stained grout, but it doesn’t measure up on new installations & I’ll not use it again unless someone tells me where I blew it.
Just a warning!
  1. Karrl | Jun 21, 2005 08:19am | #1
    I am a slab fabricator not a tilesetter but have used epoxy grout on numerous occasions instead of caulking where backsplash meets countertop and for the sink to countertop seal.
    I have had zero problems/complaints. I can imagine it would be extremely messy to clean up on a large tile expanse. I always use acetone and a rag and have never tried other methods.
    I am especially surprised it holds up for the sink to countertop seal over time. I figured the sink would move due to temperature changes and break the seal but the oldest is 3 or 4 years old with no complaints.
    The reason I used it on the sink seal is that caulking always gets so grungy looking over time and the epoxy grout is very easily scrubbed clean.
    I use C cure brand and it is a chore to mix if cold and can cure rather quickly in hot weather if left in a large mass (ie. bucketfull).
    Sorry to hear about your misfortune but I am not even sure yours was an epoxy.
    karl
    1. JimGageEagle | Jun 21, 2005 05:29pm | #2
      Thanks for the reply, Karl.  No, it's not epoxy.  Used that with great results.  This is a new product by TrafficMaster and 3M Scotchgard.  Customers will find it because Home Depot now carries and promotes it.
  2. joeh | Jun 22, 2005 12:37am | #3
    I wuz wondering about that stufffffffffff.
    Epoxy is a bitch, but it works. It's expensive too.
    Plain ol grout mixed with admix instead of water works good, seems to resist stains and no other problems I know of.
    Guess I'll stick with that until something better comes by. Doing it twice due to cracks doesn't sound like fun.
    Thanks for the heads up.
    Joe H
Outdoor Lighting
