Stains on Stucco
FoamMan | Posted in General Discussion on August 12, 2005 08:26am
Problem: Dirt streaks / stains on stucco.
I have tried power washing them and using bleach (diluted and full strength), scrubbing them and using an assortment of other chemicals (not at the same time).
I cant do anything but lighten them. Is there a trick to cleaning the stains OR should I give in and repaint. if I repaint is there a special paint or a certain brand that works better on stucco??
    SamT | Aug 12, 2005 03:49pm | #1
    Foamy,
    Clean the stains with dilute muriatic acid, AKA swimming pool acid. Start with a 10:1 diltion in water. If that doesn't do it, try 5:1. let set a few minutes. Rinse well.
    Recoat with stucco colorcoat wash. A wash is when the colorcoat is mixed with a lot of water to thin it out. Sponge on. Might take two or three coats.
    You can mix one colorcoat with white to fade it, black/grey to dull it,  or mix with other colors to get the shade you need to match.
    You can try unsanded colored tile grout. It comes in smaller packages than colorcoat. I just parged our basement with sanded tile grout. I'll let ya know in several years how it worked, longevity-wise.
    SamT
    1. FoamMan | Aug 13, 2005 07:34am | #2
      Thank you ill give this a try it!! (figures the 1 chemical I don't have on my shelf, but its on sale at the depot)
