stair hand rail
danz857 | Posted in Construction Techniques on November 23, 2007 11:05am
Hello,
Need to install a simple hand rail along a set of 6 steps to the basement, would be thankful for some tips on getting the railing to run parallel to the steps. Also what height should the handrail be an how is this measured….from the slope or riser?
Dan
    JDRHI | Nov 24, 2007 12:58am | #1
    Hand rail heights vary by local ordinances to some degree.
    Where I am, 42" - 44" from the nose of the treads is the desired height. I stick with the lower so that children can reach more easily.
    Easiest way is to sit a 4' "T"- square atop the stringer and mark the desired height at the studs.
    J. D. Reynolds
    Home Improvements
    1. gordsco | Nov 24, 2007 11:27pm | #12
      I've used the framing square to mark handrails for years, I got into the habit of laying my 6' level across the noses and set the framing square atop to get an accurate mark.
      This drywall square idea is brilliant!
      Gord
  2. robert | Nov 24, 2007 01:02am | #2
     IF you mean a rail attached to a wall?
     Take a Framing Square and place the short side atop the noses of two treads.
     Now, mark the end of the long side.
     That mark should be the BOTTOM of any hand rail.
     that's how I marked every one of the hundreds I've hung
     Also, wall rail should be 1 1/2" off of the wall
  3. RW | Nov 24, 2007 01:12am | #3
    I suspect your local code has opinions on height. I know ours by heart, but 30 miles down the road . . .
    Ours, the top of the rail must be between 32 & 36" high as measured plumb from the nose of the tread, and 1 1/2" min from the wall. It must extend a minimum of 3" past the nose of the bottom most tread and likewise at top.
    Real trucks dont have sparkplugs
  4. DougU | Nov 24, 2007 03:59am | #4
    I was going to offer up my advice but if you go back and re-read Roberts that's pretty much what I would have posted!    97448.3
    my only difference is the mark that I make at the top of the framing square is where I locate the bottom screw in the wall bracket.
    Edited 11/23/2007 7:59 pm ET by DougU
    1. Piffin | Nov 24, 2007 04:36am | #5
      That sounds reallly easy Doug, compared to all I go through lining and double checking to get it 36" above the leading edge plumb line.What height does that end up placing the rail?
      1. DougU | Nov 24, 2007 06:01am | #6
        Piffin
        I had to go do some measuring! I've done it this way for so long that I don't believe I have taken a tape to one in over 15 years!
        Depending on the bracket your handrail at its top will come out to around 34-36", I've never had one not pass. I learned this back in the day of trac-home work where there was no time for measuring anything :).
        I should mention that these numbers are approx's cause it would depend on the rake to be exact.
        Edited 11/23/2007 10:04 pm ET by DougU
        1. Piffin | Nov 24, 2007 06:05am | #7
          Definitely one to remember!
        2. BillBrennen | Nov 24, 2007 06:50am | #8
          Doug,Thanks for a cool trick. Who would have thought?Bill
        3. Jim_Allen | Nov 24, 2007 07:03am | #9
          That's how I was taught to do it too Doug. I never can remember if it the screw hole or the bottom of the bracket so I always end up double checking it anyways. I prefer them lower. I'm always thinking of kids and the elderly. FKA Blue (eyeddevil)
          1. danz857 | Nov 24, 2007 06:03pm | #10
            Thank Doug for the tip will make it much easier.
            Dan
          2. Piffin | Nov 24, 2007 08:11pm | #11
            Let's not leave robert out of the credits. Doug corrected and elaborated, but robert brought this trik up first
          3. robert | Nov 25, 2007 08:41pm | #13
             I just don't have the talent or time to draw it in.
             On the other hand, I've never had one fail for making that point the bottom of the rail.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
