Hi,
I’m replacing some carpeted treads with oak treads. The new treads are 1″ with a radius on the nose. Is there an optimal distance the nose of the tread should overhang the riser?
Thanks, Richard
there is a code for the overhang...
i like to use the thickness of the tread for my overhang but it still has to fall within a minimum of 3/4 and a maximum of 1 1/4
i don't know how this relates to stone treads... for example a 2" bluestone tread would look odd with a 1 1/4" overhang...hmmmmmm
Thanks so much to all of you. I will go with 1" to 1-1/8 overhang based on my overall layout.
Richard
Is there a code for the overhang?
Only thing I ever recall on that subject is the " minimum 9-1/4" parallel, nosing- to -nosing.
Bing
talked to my BI this morning.. we both agree that the nosing code is plain.... minimum 3/4 and maximum 1 1/4
so i guess that is what the bluestone treads will be
i looked in a lot of sources and they seem to pay very little attention to nosing overhang
finally went down to one of the public buildings. they weren't much help.. apparently they paid little attention in the stair layout
big 2" thick bluestone treads with 3/4 overhang for the nosing..... a little lameMike Smith Rhode Island : Design / Build / Repair / Restore
Like Mike said, I think it's 3/4" to 1-1/4".
If you're going to add a small cove (3/4" x 7/8", for example) under each nose, then you'd definitely have to go with the larger overhang. Lots of times, the exact overhang just depends on the unit run (i.e. tread depth without the nosing) and whatever size tread works out the best without having to spend time ripping them down on a table saw. See what you think looks best.
Edited 2/21/2007 11:16 pm ET by Ragnar17
Richard
In the future....Click on REPLY....when the response screen opens, click on the drop down menu in the upper left hand corner.....below the name of the poster you are responding to, and to the left of the "Others" tab. Inside drop down menu, click on ALL. Your single response will not need to be addressed individually.
J. D. Reynolds
Home Improvements
Thanks for the reply tip.
Richard
Like said, by code overhang is min. 3/4 to max. 1 1/4".. I and everybody I know use 1 1/4" overhang. Reason being is that treads have a 1/2" rad. roundover, so---1 1/4" minus 1/2"-- leaves a 3/4' flat-- which is just enough flat to put the 5/8" cove trim under tread. And treads come in 11 1/4 or 11 1/2" depth and most always have to ripped to size.
Roger
Richard
1.25"
I am building stairs with two 4x12 timber stringers, open risers with 7 3/4" rise and 9 1/2" tread. Approximate run 10 ft. My plan is 4 inch thick solid stairs and I am wondering if I need to stay within the max 1.25" nosing. This is not is a code area but I want it to be safe and look good.
You should have started a new thread. This one is 12 years old. I have never heard of any code prohibiting open stairs without risers.
