I want to build a bedroom in my attic. Does anyone know what the code requires for a minimum stair width?
In older homes like these, the main remodeling goal is often a more welcoming, more social, and more functional kitchen.
36" clear above handrail height. Handrails and below can project I think 2.5" into the 36" space. Newel posts can project into 36" space.
Stairs that are 36" wide feel pretty narrow; it's nice when you can make them 42" or even 48". On the other hand, for things like a "storage loft" you can use a captain's ladder for access, which is in the range of 16" to 24".
Local codes vary. Common requirement is 36". There's a lot more to it than you might think. Here is a helpful guide that will get you going as far as the list of requirements beyond just width.
http://www.stairways.org/pdf/2003%20Stair%20IRC%20SCREEN.pdf
Ideally, talk to your local building inspector.
Seeking perfection in an imperfect world is a fool's errand. Making something look perfect is a whole 'nother story . . . .
Give some thought to getting the mattress and dresser up there, especially if there is a turn in the stair.
the mattress is usually not the problem!
Queen sized boxspring... those are often trouble.
